7 members (GRNHydra, Paul_WNC, msmall, WICruiser, Wayne67vert, Otto Skorzeny, TUTS 59),
234
12
Mod | | | Forums66 Topics128,078 Posts1,056,039 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 88 Member | | Member Joined: Jul 2005 Posts: 88 | During a recent R&R of the cylinder head in my '53, the factory mechanical sending unit line separated itself from the water jacket fitting. Are replacement ones available anywhere, or is this going to be a search for a good used one? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | R.F.
If you click on the American Classic icon at the top of the page you will find they have new complete gauges for around $50.00...can't beat that with a BFH!
Stuart | | | | | Joined: Jul 2005 Posts: 88 Member | | Member Joined: Jul 2005 Posts: 88 | Can't beat it with a hammer, but I can by a buck! Just found new ones at Jim Carters for $49! Thanks for the help though. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | R.F. I am certainly not one to preach poor consumerism, but if you think the question you posted and the answer that was given was worth a buck, maybe you should consider American Classic....they are a sponsor of this site. Stuart | | | | | Joined: Jul 2005 Posts: 88 Member | | Member Joined: Jul 2005 Posts: 88 | No, I was just pointing out the fact that I had stumbled across Jim Carter prior to your response. Had nothing to do with pricing, just a response to the BFH comment. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | but remember Stuart, Carter is offering a 20% off to 'bolters only right now, which makes it better by 10$ Bill | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bill,
You are right! $10 might be enough incentive for me too.
Stuart | | | | | Joined: Jul 2005 Posts: 88 Member | | Member Joined: Jul 2005 Posts: 88 | Originally posted by red58: but remember Stuart, Carter is offering a 20% off to 'bolters only right now, which makes it better by 10$
Bill Actually, $10.80! | | | | | Joined: Jan 2004 Posts: 22 Apprentice | | Apprentice Joined: Jan 2004 Posts: 22 |
Later JJ and 4 Keep the shiney side up
| | | | | Joined: Sep 2005 Posts: 29 Junior Member | | Junior Member Joined: Sep 2005 Posts: 29 | If you are ever going to a small block (which doesn't sound likley too soon due to your R&R of the 6 cylinder head) you might get a guage with a longer tube due to the up front location of the sensor. Just thought I'd mention it - I drove for awhile with the sensor hanging in air untill I popped for a new gauge/sender with a longer tube for the V8. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | I know this will upset someone,but at Wal-mart or big lots you can get a Cheap set of gauges for $9.95.That oil ,amp, temp.There Cheap but they work fine.An they don't look bad :p :p
dan-pa
