| | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | Does anyone make a big window conversion kit for a 56 chevy pickup? If so, where could I get one? Any help would be greatly appreciated. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "conversion kit'?  GM made one - find a cab that has a big window, cut it at the belt line, cut your small window the same, transpose the 2 tops sorry, couldn't resist - if you could look at both cabs at the same time you can see that what would be needed for a conversion "kit" would be 2 cabs, a well equipped body shop, and an excellent bodyman - the glass is available from an auto glass shop Bill | | | | | Joined: Sep 2005 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 96 | ricos rods and relics has one, but it's not out yetbut maybe in a couple of months. www.ricos-rods-and-relics.com | | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | Thanks, now I have another question. Where can I get some money? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Brent like this small window? - no doubt made by Dynacorn - even tougher than nipping the top off an original cab IMO - remember that there's an 'inner' body as well as that outer shell, and that needs the larger opening too, and those 2 panels are pinch welded - on top of the 500$ patch cost, you'd be looking at at least a thou to install it you'd be best off to find a decent big window cab Highschooler, and just switch cabs - even trade the small window for it, as many folks would rather have that! 90% of the TF cabs ya see are small window tho, so it won't be too easy to find a loose big window cab Bill | | |
