1 members (Hotrod Lincoln), 73 guests, and 1 robot.
Topics128,055
Posts1,055,782
#194515 11/29/2005 6:28 AM
It's stuck. I've tried the BFH and it won't budge off the spline in the steering gear assy. Any ideas? Or should I take it to the machine shop and have it pressed off? :confused:
#194516 11/29/2005 6:33 AM
Have you tried any penetrating oils to loosen it?
#194518 11/29/2005 12:18 PM
I used a gear puller with lots of penetrating oil.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#194519 11/29/2005 12:55 PM
Those arms are made to come off with a puller. There is almost no play when it is seated on the splines and force from a hammer just causes it to jam even more. The puller provides even tension.
1951 1 Ton Completed
#194520 11/29/2005 3:27 PM
Riding in the Passing Lane
Get a pitman arm puller. They are reasonably priced at a discount tool supplier.
1972 Chevy c10 Cheyenne Super
#194521 11/29/2005 4:42 PM
Thanks guys,
I'll follow your lead.
#194522 11/29/2005 6:40 PM
You may be able to get that puller from your Auto Zone tool lending program-- free of charge.
#194523 11/29/2005 11:43 PM
I nearly cut off my left middle finger at the first knuckle when a pitman arm I was removing let loose on my Jeep and bashed my finger into the sharp edge of the oil pan. I know a stovebolt has a differant location on the pitman but watch out because they let loose really fast. It's best to leave the bolt on there loose until you get it loosened up so it doesn't pop off and kiss you in the mouth or something. A pitman arm makes a pretty good hammer.
Paint & Body Shop moderator
#194524 11/30/2005 4:51 AM
Junior Member
Junior Member
Best bet is to get a good quality pitman arm puller, tighten it up and if the pitman arm still won't move hit it with a hammer. This will jar it loose. I have used this method on at least 20 trucks with no problems.
Wise Man Says "A siezed bolt is not a problem, but an oportunity to use the torch."
#194525 11/30/2005 5:14 AM
The BFH is a useful tool, but use it sparingly on the steering box. The sector/shaft is
supported on that end by a bushing which isn't BFH resistant. wink
Stuart
#194526 11/30/2005 7:23 PM
The best place to tap with the BFH is actually on the side of the pittman arm where the shaft goes through, not on the shaft itself. Tension the bolt on the puller first, and then tap on the arm. The shock breaks the friction weld on the arm and the puller pops it loose. Lather, rinse, repeat until it comes off.
#194527 12/06/2005 1:50 AM
Great advice 4onthefloor. Loosen the nut and then loosen the pitman arm. Where were all those great ideas I found out about after I skint all those knuckles?
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
#194528 12/09/2005 2:46 AM
The Pitman Arm puller I was loaned from the Auto Zone took about 10 seconds. It just slipped right off. Thanks for the advice and the lead.
They've got a tube bender and double flarring tool for loan as well. Next stop, the new brake system. smile
