1 members (NJC), 132 guests, and 2 robots.
Topics128,162
Posts1,056,941
Members48,458
A few weeks back (I think in the Rare options thread) there was mention of something called a Cattle or Cow horn.
Most folks who have spent time around cattle know that they can be conditioned to come running when you call them, or honk a horn during feeding time.. but this magical device is supposed to emit a sound that no bovine can resist, and send them running to you regardless of conditioning.
So I gotta know.. where can I get one?
Didn't JC Whitney used to have a 'Bull Horn' that had a long lever on it so you could modulate the sound and make it moo?
well i started a thread in this section on the horn my truck has. but its stock looking, so not sure if it was original or not. it was red, but its faded and rusty looking now. its mounted to the intake. i dont know enough other then what i was told. so anyones guess. search the cow horn thread to see the original posts.
Jed Offline
Fumblin,
There have been at least one, and possibly a couple of them listed on E-Bay during the last few weeks.
I'd seen them just prior to reading that post you're talking about, but haven't been able to find them again since then.
I was looking at wolf whistles, when I came across them. You might try some different search techniques out there and see what you can find, cause I know they're there.
The cows have been known to put a few dents in your truck also grin
Redryder pix
My Hotrod
Jed Offline
I got mine from JC Whitney about 2 years ago. Works with a cable and a lever.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
well thats exactly what i have on mine. mine rust color, but used to be red. sounds a bit like a sick cow now though. but it has to be the best horn ive heard in a long time. if anyone finds a place that sells them, i want another one....ok im gready, sue me :p
My uncle had one and used to blow it when he came down the driveway, the Holstiens would come from the pasture on a dead run!
You never have enough, til you have too many!
Jed Offline
JCWhitney does have a couple of different versions. One is designed to be used as a replacement for your current horn.
It's $44.99. Their catalog #WK812716. I think you need the installation kit for this one, $7.99, catalog #WK888315.
They also have the one described by 56picup. $79.99, catalog #WK142568.
If you have a catalog, they're on page #140.
By the way, both horns are 12 volt electric.
[IMG]<img src='http://img.villagephotos.com/p/2005-10/1092158/Dsc01238.jpg' width=640 height=480 >[/IMG]
heres the one on my truck in all its glory.....well ok. rust.
The cows either love 'em or hate'em. My 50 pickup has one that has been there since 51 or 52. My brother inlaws cows needed to be moved from one pasture to another. It was just a short 5 minute deal but it was cold. About 50 head. We decided to use the trucks. They were moving towards the wrong gate and we had them going everywhich way. I got ahead of them ,with all the power that the 216.5 had, and gave them a little cow horn toot. they turned and went across the 25 acres,into the correct pasture. and took 50 yds of fence with them. We couldn't catch them once I tooted. Don't know if they liked it or not.
My uncle had one of those on his jeep. I have to agree with fatboy, you could do a better job of chasing cattle than calling them.
Fred
52 3600
69 C-10
The horn doesn't matter it's what you do with it. At least 1-2 weeks before you want to move a heard of cattle, show up with a sack full of cattle cubes or some other sweeet feed they love.
Blow the horn over and over, and throw out the feed. Come back the next day at the same time and repeat.
Within a few days, Pavlov takes over and they will follow that horn like it's mamma calling.
It helps to have an extra horn, that way using your normal horn won't confuse their bovine minds.
don't have the original on the 50. found a elec. one someplace, sound must not be to bad, drives buster the neighbors bull crazy...
Drive with Pride. mike j
family pic
does the original bull horns run off vaccum or 6 volt battery? and i'm guess its a pull switch (like a choke cable) that is used to blow it, from what i can tell from demo man's picture
Nate
Link to my photobucket for pics of my vehicles
http://s238.photobucket.com/albums/ff17/OldIronChevy/
It was my understanding they would honk with the regular horn button, but used a pull cable to alter the tone.
My cow horn works separate from the stock horn. It has a lever like the turn signal. Cable runs to the horn. It is wired right to the six volt battery. You can make sick cow sounds all the way to the strong bull beller........ You can run the battery down too..........not speaking from experience ;-]
