1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#19436 11/06/2002 10:45 PM
I am just about to get my 53 3800 frame on wheels, and have run into a small problem. the front drums/hubs i have are the offset type and i want to go with the standard drums. my question is will the front drums from a 58 3/4 ton work on my 53 axle?? i am considering buying a parts truck (58 3600) and need to know if they will work.
I do not recall if the spindles are the same diameter.If no one gives and educated/experienced answer ,call an auto parts store and see if the bearings are the same.If they are, they should swap ok cool
One more thing to consider, the front brakes on a 1-ton are 12 inch and the ones on the 3/4-ton are 11 inch.You will need to swap the backing plates to fit the smaller drums if, IF they will fit the spindles smile
Phil,
From the '59 parts book.
HUB, Front Wheel
47-59 3/4, 1 TON w/sgl. wheels ... (cast 3683232).....p/n 3683232
47-59 1 TON w/dual wheels,
53-59 3/4 TON w/dual wheels (exc. D-D),
55-59 D-D w/dual wheels (2nd series)..
...(cast 3683818).... p/n 3683818
KNUCKLE-SPACER, Steering (with nut)
53-59 3/4, 1, 1-1/2 TON (exc. D-D, SBC, hvy. duty)...(forged 3698332)..p/n 3703563
Hubs are different but spindles are the same so it looks like your good to go with the 3/4 ton parts.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
