1 members (carbking),
103
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I am going to install a/c in my 64 230 driver over the winter. Has anyone custom engineered any compressor mounting brackets on a six? I have a MIG, looking for ideas or pics of other setups,,thanks Brian | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | GM made factory brackets for the 230-250-292 six. I haven't seen many on a 64 but by 66 a/c was getting more popular and a 66 has the same configuration as your 64. Maybe someone with this setup could send you a pic. I have also seen aftermarket brackets that were for the York type compressor rather than the Frigidare. Hit the swap meets and look at all the 64-66 trucks with the hood open and you might score.
Evan
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I am running an HEI which may be in the way of mounting a long Frigidair, although I found a HEI w/separate coil & bought it but not installed yet. It still may be too tall. I scored some pulleys off ePay & a two groove dampner off a 66 GMC 250. I was thinking of using a smaller, possibly(ugh)import, compressor like a Sanden to ease the burden on the six. I would love a pic of someone's setup, around here at shows no one keeps a six, they are dumped for a 350. Brian | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | If you get brackets for a 194/230/250, make sure they aren't from the integrated head version. The 292 brackets probably won't fit due to the increased engine height. | | |
