1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19432 09/09/2004 4:58 PM | Joined: Sep 2004 Posts: 24 New Guy | | New Guy Joined: Sep 2004 Posts: 24 | the pulley on a 235 ci , is it pressed on ,so I need a pulley puller to remove it ? | | |
#19433 09/09/2004 5:23 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | Yep, your local FLAPS will have one, mine cost under $15.00, worked like a charm. | | |
#19434 09/09/2004 5:35 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Very easy to do but of course you probably already know the rad has to come out. Putting it back on requires hammering. I used a brass block to "soften" the hammer blows. | | |
#19435 09/09/2004 7:02 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | What you're wanting to remove is the harmonic balancer. Is there a reason why you're wanting to pull it?
Fred 52 3600 69 C-10
