2 members (NorthCoast3800, DadsFirstPickup), 53 guests, and 3 robots.
Topics128,153
Posts1,056,849
Members48,456
#19432 09/09/2004 4:58 PM
mj
Offline
the pulley on a 235 ci , is it pressed on ,so I need a pulley puller to remove it ?
Yep, your local FLAPS will have one, mine cost under $15.00, worked like a charm.
Very easy to do but of course you probably already know the rad has to come out. Putting it back on requires hammering. I used a brass block to "soften" the hammer blows.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
What you're wanting to remove is the harmonic balancer. Is there a reason why you're wanting to pull it?
Fred
52 3600
69 C-10
