Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 95 guests, and 0 robots.
Topics128,274
Posts1,058,433
Members48,490
Just got the outside door handles on and they are straight with the door open, but hang down when the door is closed.
I guess the latch is not extending as it should.
I have new stricker plates and wondered if they are not adjusted quite right.
I have seen springs you can buy to cause the handles to pull back horizontal.
Maybe that's the answer.?
Any ideas?
Regards, Kevin
1940 1/2-ton (Uncle Willie\'s truck)
Thanks for the help so far fellow Bolters!
Sounds like the springs are weakening, I'm presently doing the doors on my 46 which is probably the same as your 40 and the latch spring on the passenger side is much stronger than the drivers side. I gave both mechanisms a good soak in WD40 and it seemed to cure the problem.Also check the leaver that goes from the inside door handle to the mechanism. they wear out as well and can cause the handles to sag.
BobT
Kevin- Check to see if you have the return springs on your latches. I was missing them on my truck. Once I installed those, the handles stay horizontal. I've got some pictures of the springs and the latches, if you want me to email them to you. (sorry I'm unable to post them here)
George
New handle springs should do the trick...
Another quality post.
Real Trucks Rattle
Kevin I have noticed with my 46 that if you have the inside handles set horizontal and you close the door by shutting it without using the outside handle that mine will sit straight. If I try to close with the handle it wont work. Someone also told me you can ruin the mechanisim by closing with the handle. Don't know if it is true or not but why take the chance
Stuart
