6 members (50Chevy3100, Buckeye998, JoergK., ShopRag, Lightholder's Dad, Rusted Nut), 348 guests, and 3 robots.
Topics128,160
Posts1,057,054
Members48,463
does any one have a mustang 2 frount end under your truck with a v8 in it looking to do this to my truck but would like to know the finish ride higth on frount.also what kind of rears are you guys using with out cutting them down
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
Apart,
As far as rearends go, Mid-70's Nova, Camaro, Firebird and some olds products will be the correct width, but you need to weld on new spring perches. Also, GM S-10 4X4 Blazer/truck rear will be close too.
As far as finished height, I have seen M II that are a couple of inches lower to right down in the weeds....
help i dont want a dirt diger but would like to retain orginal ride highth
AND A MARINE
Jed Offline
Hillbilly,
I have a stock 46, so I can't tell you from experience about a MII.
However, I've never seen any type of suspension change that maintained the stock ride height on an Art Deco truck.
I'm trying to imagine something (other than stock) that could be done. Frankly, every possibility I'm coming up with, would probably look ridiculous with the truck sitting that high above the front non-stock suspension.
I'm curious to see if someone else has ever seen anything that worked well and kept the truck that high. Good luck in your quest.
help please
AND A MARINE
Junior Member
Junior Member
Frame swap like i am doing/ 76 gm.Then you could raise or lower it with new parts.
