| | | Forums66 Topics128,176 Posts1,057,058 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | does any one have a mustang 2 frount end under your truck with a v8 in it looking to do this to my truck but would like to know the finish ride higth on frount.also what kind of rears are you guys using with out cutting them down
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Apart,
As far as rearends go, Mid-70's Nova, Camaro, Firebird and some olds products will be the correct width, but you need to weld on new spring perches. Also, GM S-10 4X4 Blazer/truck rear will be close too.
As far as finished height, I have seen M II that are a couple of inches lower to right down in the weeds.... | | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | help i dont want a dirt diger but would like to retain orginal ride highth
| | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Hillbilly,
I have a stock 46, so I can't tell you from experience about a MII.
However, I've never seen any type of suspension change that maintained the stock ride height on an Art Deco truck.
I'm trying to imagine something (other than stock) that could be done. Frankly, every possibility I'm coming up with, would probably look ridiculous with the truck sitting that high above the front non-stock suspension.
I'm curious to see if someone else has ever seen anything that worked well and kept the truck that high. Good luck in your quest. | | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 |
| | | | | Joined: Apr 2004 Posts: 4 Junior Member | | Junior Member Joined: Apr 2004 Posts: 4 | Frame swap like i am doing/ 76 gm.Then you could raise or lower it with new parts. | | |
