1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#193460 11/14/2005 1:44 AM
Anyone ever use the engine paint that Chevy Duty sells (PPG ALK200) on the intake manifold? I'm thinking the heat from the exhaust manifold will burn it off. I painted the engine yesterday and it looks sweet! If anything, I'll paint the intake the same as the exhaust manifold- cast iron gray, but I'd rather have it more original.
#193461 11/14/2005 2:50 AM
I think Bill Hersch sells what you'll need for the original look..they have high heat paint..B. Duykers
bruce duykers
#193462 11/14/2005 3:28 AM
Regular car paint should work on an intake manifold, but not on heads or exhaust manifolds. You could check at your local parts store for high-heat paint in a spray can, if you don't have to have the original color. some of that stuff is rated for up to 1500 degrees.
#193463 11/14/2005 3:49 AM
I painted my intake with the same paint I used on the block and the head. Duplicolor engine primer and then top coat. I think it's rated at 500°. It has held up well so far. 6000 miles. I have the high heat on the exhaust manifold that has held up just as well. cool
