| | | Forums66 Topics128,035 Posts1,055,446 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | ...As to which year rear drums I can use on a 46 3/4 ton with huck brakes.
It seems like the 8 lug Huck style drum was used from 1946 until 1950 or 1952. Then they switched to Bendix, and all the parts are different.
Am I right, or am I full of something?
And if I'm full of something, which years can I use?
Any advice would be appreciated. | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | I don't know what you might be full of, but you are correct. 46-52 3/4-ton used the same rear drum (original part #609807).
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | You've got it right. 46 to 52 3/4 ton are the same. | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Thank you! (I'm full of crap anyway. Just not about this!)  | | |
