8 members (WICruiser, Southerntruck, jaycoop, 42465967, 2-Ton, Shade Baby, Joe H, TUTS 59), 127 guests, and 2 robots.
Topics128,129
Posts1,056,362
Members48,441
#193183 11/10/2005 8:35 PM
I have the heavy duty, granny low, 4spd in my 61 and I am wondering if there are any other manual transmissions that would fit this thing. Particularly I am looking for somewthing with an overdrive, maybe even a 5spd? I am thinking of replacin the 4spd, and regearing the rearend altogether. I really want to be able to drive my truck on the highway at 65-70 and not feel like I am going to make it blow up, thoughts and ideas appreciated
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#193184 11/11/2005 3:14 AM
An S10 T5 would work fine and you could keep your original rear end which is probably 3.90? With the .70 overdrive your final gear would be 2.73
#193185 11/11/2005 9:05 AM
gaffbro - how much modification does the t-5 require? what do i need to change to mount it to my 61 235? is it hydraulic? do i need to modify crosmembers? driveline modifications? suggested years and models of s-10's to hunt for? is this the same t-5 that the camaros and other gm's have? i am new to this and unfamiliar with the t-5. any help and or suggestion would be appreciated. thanks for the post.
My Machine
#193186 11/11/2005 5:52 PM
Riding in the Passing Lane
The tech tips on this websight has a good section on this. There have been many posts. you should be able to bring them up on a search.
1972 Chevy c10 Cheyenne Super
#193187 11/11/2005 6:01 PM
Here's a link to the info on the t5 swap.. sounds like a serious PITA!
t5 tranny swap for AD trucks
#193188 11/12/2005 7:13 AM
pita?
My Machine
#193189 11/12/2005 9:00 AM
Shorthand for PAIN IN THE A## eek grin
Steve sr.
#193190 11/12/2005 9:23 AM
With that granny gear 4 speed I'd consider 3.08:1 gears. The ratio on that granny gear is something like 7:1, so even with 3.08:1 gears you still have PLENTY of grunt power available, and you could run down the hiway nicely.
boo
We don't need no stinking V-8s!!
