| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 3 Junior Member | | Junior Member Joined: Nov 2005 Posts: 3 | will late model seats out of 03 or later chev trk or suv fit in a 69 chev.p.u? | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | 99-05 tahoe, suburban, yukon, silverado seats work great, and they also have built in seatbelts for pre-'66 trucks.
I used '99 tahoe second row 60-40 seats in my '56--lower back than front seats so don't stick up above the window, seat bottoms flip up, backs flip forward, uneven mounting led me to use old rubber motor mounts and washers to even things our without reinventing the mounts. | | | | | Joined: Nov 2005 Posts: 5 Junior Member | | Junior Member Joined: Nov 2005 Posts: 5 | I know the years are not the same, a guy just told me a durango rear seat or a mini van rear seat will fit 42 to 46, haven't tried it yet. | | | | | Joined: Oct 2005 Posts: 4 Junior Member | | Junior Member Joined: Oct 2005 Posts: 4 | Will late model bench seats work in a '71 C-10 with interior gas tank? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I see no reason why the later model seats would not fit. You may have to rework the floor mounts though.
What I have seen used on 67-72 is the middle seat from 92-99 suburbans being used. The seat back folds forward and the seat bottom flips up giving great access to the areas behind and under. Also seen these used in Task Force series. | | |
