8 members (MNSmith, lumbersawyer, Hotrod Lincoln, Shade Baby, klhansen, Mike B, 2 invisible), 123 guests, and 2 robots.
Topics128,139
Posts1,056,762
Members48,454
#192849 11/06/2005 5:54 AM
Ive read other posts reguarding swaping out splits for one piece rims.Are the setback isues with tierod ends a problem on a 66 or just older trucks.What abought the rears.Thanks Ron.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#192850 11/06/2005 4:57 PM
When I bought my '65 it had split rims. I had no problems when I installed newer stock steel 8 lugs. Wasn't an issue.
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#192851 11/07/2005 12:11 AM
Thanks for that info david.Its on my 66motor home,Im thinking one piece rims would be alot less hassle if a tire problem develops on the road.Im hopeing it sees a lot of miles next summer.Ron
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
