| | | Forums66 Topics128,186 Posts1,057,209 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I'm curious about how to bring a '46 up to more modern speeds.
I'd like to get a comfortable 65MPH out of it if I needed to.. everything i've read suggests the stock rear end gearing and 4 speed tranny with a 216 engine has a top speed in the 45 to 55 range.
I've seen some talk about a rear end "kit" but i'm not sure what kind of a PITA that would be.
Any ideas?
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I've always thought I might like to go the t-5 route someday, but when I do that, i'll probably go full hog and upgrade the motor to a 261.
Dosen't the open driveline conversion with the t-5 require a rear end swap?
Almost seems like it would be easier to just find an s10 running chassis and swap bodies.. at least then you'd end up with power steering and better brakes.
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | F46,
It does require a rear end swap, but you only need to weld on new spring perches. I looked at an S-10 swap as another project. That seems like a lot of work too.
My someday plan is to pickup another 41-46 frame and do another with swapped rear, MII or Dakota and a small block or 4200 Inline 6...
But that is more than a few years off... | | |
