3 members (1955 1 Series, 2 invisible),
128
Mod | | | Forums66 Topics128,195 Posts1,057,370 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19218 08/24/2004 10:11 PM | Joined: Mar 2004 Posts: 21 Junior Member | | Junior Member Joined: Mar 2004 Posts: 21 | 1951 dually, one-ton flatbed model 3800
I sent my brake shoes off and got them relined but am having a hard time finding the springs and clips for the shoes.
Called Chevy Duty, they don't stock them for the one-ton. And Brake and Equipment Warehouse in MN is not sure where to find them.
Any help? THANKS | | |
#19219 08/25/2004 2:24 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | try Jim Carter in the links section | | |
#19220 08/25/2004 2:41 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I can't see why a standard C clip of the proper size would do the job. Anyone have opinions on this? | | |
#19221 08/25/2004 2:47 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Do you know what size clips you need? and how many?
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#19222 08/26/2004 6:05 PM | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Blue: I had the same problem with my NAPCO brakes, couldn't find springs or clips. The brake warehouse in Minneapolis couldn't help me. I tried various advertisers that specialized in old brake parts, no help either. What I finally did was go to a parts store (in my case Checker Auto Parts). I went through every brake springs/fasteners kit and matched my old parts. Then I bought the kits I needed. | | |
#19223 08/27/2004 5:21 AM | Joined: Mar 2004 Posts: 21 Junior Member | | Junior Member Joined: Mar 2004 Posts: 21 | thanks for the help. I'll do some research and let you know what I find.
The C-clip idea sounds like it should work. Hope to find a spring that will fit as one is already broken.
appreciate the tips. | | |
