2 members (John Dlugos, 1 invisible), 150 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
#191934 10/24/2005 1:03 AM
Anonymous
Unregistered
Anonymous
Unregistered
What are the symptoms of a master cylinder giving up the ghost? Vehicle in question is a 99 Suburban. No wheel cylinder leaks but air seems to be getting into the lnes evidenced by air bubbles in the brake fluid in the rear portion of the master cylinder res.
#191935 10/24/2005 1:15 AM
1999.
#191936 10/24/2005 2:43 AM
I dont think its a hard and fast rule, more like a guideline. I think people should be able to ask an off topic/year question once in awhile. Especially someone who has offered help to many others in the past. I appreciate any knowledge I might gain, even if it doesn't necessarily apply to an older vehicle. Who knows, maybe it will.
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#191937 10/24/2005 3:19 AM
Sounds like the MC is bad.. had this happen to me- air will sneak in past a bad seal at the back of the MC where the pushrod hits it.
#191938 10/24/2005 1:45 PM
Anonymous
Unregistered
Anonymous
Unregistered
Since many bolts, including mine, get brake system transplants using later model components this topic is perfectly fitting for this forum.
I got one useful suggestion. Is there a specific test I can perform to confirm the MC is gone?
#191939 10/24/2005 3:46 PM
Riding in the Passing Lane
Rear disc or drums?
1972 Chevy c10 Cheyenne Super
#191940 10/24/2005 4:03 PM
Anonymous
Unregistered
Anonymous
Unregistered
Drum rear, disc front.
I have since been educated that the larger (rear) section of the master cylinder is for the front brakes (large volume needed for calipiers) and the smaller section of the master cylinder is for the rear brakes. Therefore the frothy brake fluid is from the front brakes.
#191941 10/24/2005 4:21 PM
Quote
Air bag explodes. eek
Gord
1954 1/2 ton 235 4 speed
#191942 10/24/2005 4:44 PM
Anonymous
Unregistered
Anonymous
Unregistered
HA HA HA ....HA BOO! wink
