1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 36 Apprentice | | Apprentice Joined: Aug 2004 Posts: 36 | I just bought a radiator from a vendor and the stock fan bade hits the bottom tank. My truck is stock and my original radiator, a Harrison 5120 radiator fits perfect, its 20 by 20 core size and the tank bottom is even with the core anyone else have this problem? These new proded radiators are three core kind of fat with the brackets moved out instead of in. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Is the engine the original 216 or a later model 235 ?
-W | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I had my Harrison recored from a 2 row to a 4 row at a local radiator shop. I originally bought one of those repro's and I believe I had the same problem which caused me to look into have what I have fixed.
Best thing I've done.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Aug 2004 Posts: 36 Apprentice | | Apprentice Joined: Aug 2004 Posts: 36 | my truck has a 235 however I was advised to use this special water short pump.The radiator is the original Harrison and it works great however it's 52 years old. | | |
