| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Ok, This could be interior or exterior so I wasn't sure where to go. I have a 46 chevy 1/2 ton and I am ready to replaced the window and door gaskets. I have the 46 resto manual from chevy but it is not vary go for 41-46 it is more for the cars than trucks. Anyway here is my question, I have never done windows/door gaskets and am not totaly sure what the glue and tape is for. Can anybody help with what and where these are used and how much I need. Also any suggetions to make the job easier would be great.
Thanks in advance. Ed | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | If i uderstand your ? right The tape is used for setting the front glass, but i just used a silicone glass sealer for my front window and just trimed of the exsses with a razor blade, turned out real nice. When I installed the rubber windlace I just used the metal trim to hold it in place, no glue. Iam glad I did because I had to lossen a few screws and pull the rubber out futher to get a better seal around the door Stuart | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Thanks,
I will give it a try and let you guys know how it went.
Ed | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My supplier recommended the silicone over the tape and he sells the tape! | | |
