1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#191546 10/17/2005 7:11 PM
Ok, This could be interior or exterior so I wasn't sure where to go. I have a 46 chevy 1/2 ton and I am ready to replaced the window and door gaskets. I have the 46 resto manual from chevy but it is not vary go for 41-46 it is more for the cars than trucks. Anyway here is my question, I have never done windows/door gaskets and am not totaly sure what the glue and tape is for. Can anybody help with what and where these are used and how much I need. Also any suggetions to make the job easier would be great.
Thanks in advance.
Ed
#191547 10/18/2005 6:22 AM
If i uderstand your ? right The tape is used for setting the front glass, but i just used a silicone glass sealer for my front window and just trimed of the exsses with a razor blade, turned out real nice. When I installed the rubber windlace I just used the metal trim to hold it in place, no glue. Iam glad I did because I had to lossen a few screws and pull the rubber out futher to get a better seal around the door
Stuart
#191548 10/18/2005 1:59 PM
I will give it a try and let you guys know how it went.
Ed
#191549 10/18/2005 2:55 PM
My supplier recommended the silicone over the tape and he sells the tape!
1951 1 Ton Completed
