9 members (John Dlugos, Buckeye998, Gray_Ghost, Gdads51, dt235sd, rfs56trk, BCBill, Otto Skorzeny, Dusty53), 236 guests, and 0 robots.
Topics128,101
Posts1,056,172
Members48,436
Hey everybody..
What a great site this is! I'm a new member and have picked up some great info here.
I'm hoping someone can help me out with a problem I have.
Back in July I bought a '65 Chevy Fleetside long bed Custom Cab big window. It came with a nice chrome horn ring. I noticed it needed a little cleaning in the nooks and crannies. I took the horn ring assembly apart and cleaned up everything. It came out great. No pitting and all shiney now.
Problem is I can't figure out how to get it back together. I'm usually very careful with my work area as to not lose parts and set things in place in order of assembly.
To make a long story not too much longer..I'm not sure if I lost any pieces or not. I can put it back together but there's no "spring" action to make the electrical contact. I sure would like honk my horn again! Any help that I can get would be truly appreciated!
radioripster
Here's a picture of what I have.
http://img.villagephotos.com/p/2005-10/1092202/hornring_assembly.jpg
Thanks again...
Socket Breaker
Socket Breaker
Someone will be along eventually to answer your question...
http://www.chevytalk.com - 1960-66 trucks forum - is another good place you might want to check out.
smile
-W
Socket Breaker
Socket Breaker
hmn- mebbe this is an interior question? I figured this would be answered by now...
-W
Junior Member
Junior Member
It looks like you have all the parts there, the piece that looks like a round thin washer with 4 holes in it, that makes the spring action. I had that type of wheel on my truck, but I swithed it to an 86 P.U. wheel because it is possible to get you finger caught in that horn ring.
Thanks for the replies.
I've gotten it
figured out and this time it works. I've tried every combination and the horn either didn't work or honked constantly. I was certain that I had lost a part or something. This last time it's right. Go figure.
So now that it's on and working ,it now falls under the category of .."If it ain't broke, don't fix it."
Thanks again for the help..
