6 members (frogfarmer, Steelonsteel, Gray_Ghost, TUTS 59, 2 invisible), 176 guests, and 0 robots.
Topics128,109
Posts1,056,268
Members48,439
#19126 06/17/2004 1:27 PM
Junior Member
Junior Member
What is the recommendation for a solvent to use for cleaning brake cylinders for rebulid? "Brakleen" doesn't seem to get it done...
My cylinders have a lot of "varnish" from old brake fulid and junk from deteriorated rubber seals.
What is a good and safe method of cleaning them before final touch-up with the cylinder hone?
Thanks!
Dave
Dave,
When all else fails and you are only dealing with metal, try lacquer thinner (if it is legally available in your area).
How close are you to West Chester?
Tim
Junior Member
Junior Member
Tim -
Thanks! I 'll get some lacquer thinner.
I am about 10 miles from West Chester, PA.
Know of any good parts stores or Used Parts suppliers?
Thanks!
Dave
A word of warning. Lacquer thinner has solvents that are not compatible with DOT3 brake fluid. Be sure to thoroughly clean with either Brakekleen or denatured alcohol (also at the hardware store).
Fred
52 3600
69 C-10
ANY petroleum-based solvent is bad news when it mixes with rubber brake parts, so always do a final flush with alcohol. I'll second the lacquer thinner suggestion, or Methyl Ethyl Ketone, if you can find some. MEK will clean just about anything, including all the oil in any skin it touches, so glove up before using that stuff! It's pretty potent in the fume department, too, so have a fan running if you use it.
My question is what is the lubricant that the rebuilders use when putting these things together? My new wheel cylinders had some kind of thin goo that was not brake fluid, coating the inside. This obviously gives them shelf life but I don't think that there is a product like this available off the shelf.
1951 1 Ton Completed
For lube use brake fluid. I use a small can and dip the hone in it, then clean the bore and smear some more fluid in it before putting in the pistons. If there are rust grooves, you need to either get new cylinders or get yours re-lined.
Fred
52 3600
69 C-10
Dave, Have you tried burning the crud out with a torch? It worked for me. The metal expands at a different rate than the crud, and it lets go of it's grip. All that was left was a little carbon residue which wiped out with a dunk in the parts tank, and a wipe with a clean shop towel.
