3 members (RonG, Forty9, Jon G), 126 guests, and 2 robots.
Topics128,163
Posts1,056,964
Members48,458
I'm interested in dressing up my 53 a little and am thinking about wide white walls. Any opinions about the correct size white walls? I see them from 2 1/2 to 4 inches wide. I see ads for Coker, Firestone and a few others. Any comments, opinions or suggestions are appreciated. Thanks.
I would go narrower than 4" myself. I think the very wide whites (4") look better on old Buicks and Packards etc. I had a set of 2 1/2" wides on my 49 but recently replaced them with blackwall tires, black rims and stock hub caps and trim rings. I had a tough time deciding whether or not to go back to whitewalls which are not cheap, so went with the black. And frankly in my opinion and opinions of others, the truck looks better.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Correct size whitewalls for a 1953 truck?
This could be considered a contradiction in terms - an oxymoron?
Whatever size suits your tastes.
I'm with Ol'blu49. I had been lusting for whitewalls but finally went with a big, blackwall tire on black rims.
I'm glad I did. But it's all a matter of preference.
The 6.50 X 16 Firestone Whitewalls from Coker look great. They have a 4'' wall.
Here is my '53 with 215/85/16 Firestone radials:
[img]http://www.whizzerick.com/shoptruck.JPG[/img]
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
I vote for zero white walls on any truck.
Mike Barnes
1950 GMC 1-ton pickup
If you like whitewalls, you should put them.
I have 7.50 X 16 bias ply ((Uniroyal) photo in my profile). But then, I didn't want it to look dressy 'cuz that's not what I was after.
Good luck.
Wizzerick- Your truck looks GREAT grin
Sabrina
Sabrina
'54 3100
If you decide to go with whitewalls I would think that Coker could advise you as to what width would be correct.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
What is meant by a "correct" width?
Whitewall tires were not an option on Chevrolet trucks in 1953.
That is why some people above are saying that if you want whitewalls, choose any width that appeals to you. However, no matter what you choose, it will not be "period correct" for a truck - it still might look good - to your tastes.
Maybe "correct" (in the original posting) refers to the size of the white wall on a '53 automobile. Coker could help you with that. In addition, it might also be "period correct" to have other-colored side walls (they were available in the '50s and I think someone posted that they are still available).
Tim
This is Greg Fall's '50 from the gallery.
It looks AWESOME! I believe he is running Firestones.
[img]http://www.stovebolt.com/gallery/images/falls_greg_1950_01.jpg[/img]
Junior Member
Junior Member
I'm running WWW on my '53 1/2 Ton. It's a mild custom, so the tires definitely suit the look. Hell, I think the tires MAKE the look.
[img]http://www.stovebolt.com/gallery/images/murphy_mark_1953a.jpg[/img]
They're BF Goodrich Silvertown's 4-ply 670-15. Overall diameter is 27.42", cross section is 7", and tread width is 4.5". The white wall height is 3 5/8" (but only 3 3/8" is visible when mounted).
Man, I am digging Greg Fall's '50!
-murph
ODSS President
ODSS President
Whizz, Greg, Murph, I DIG your wheels.
~ Cosmo
1949 Chevy Half Ton
If you like whitewalls go for it.It is your truck.Dont make any difference that someone else doesnt like them.Do it your way.As for size,go to a good tire dealer,he will have the actual measurments of what you are running now and match them up with new WWs.Good luck.
TC, "period correct" WOULD be the more correct statement for sure. Going on the fact that replacement tires were inevitable we can all assume that some truck owners would in fact decide to replace worn out factory tires with "period correct" whitewalls. My point was, that 60's era 1 inch whitewalls were not available in 53. My 59 currently wears four year old 1 1/4" Firestones which are definitely not period correct but fit in the budget during that stage of the resto.
Bruce
Jack--On my '56, I went with the Coker Classic 2 3/8" WW in a P205/75R15 (you can click on my profile above and see how they look). Like mentioned above, it's YOUR preference as to what you feel looks good. I went with wide whitewalls to somewhat contrast the black color of my truck--I like the way they look on the truck, but, that's just me talkin.
Brian56- Your WW set off your truck just right.
Murph- Yours fit your truck to a tee.
& Greg Fall's '50 looks good enough to eat!
Sabrina
Sabrina
'54 3100
I'd have to agree with the others, if'n you're wanting to do an original resto then your guidelines are cut and dry but if it's a resurrection then it's all personal preference.. and as they say "beauty's in the eye of the beholder."
Greg Fall's '50 works great with the yellow... I think blackwall's would've been too harsh a contrast. And Brian.. I think your '56 looks awesome with the ww... it works especially well because your bumpers and grille are white so it carries thru. Nice ride!
Larry Bear
55.5 Chevy 3100 Panel
