0 members (),
82
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | The 53 never lets me get bored. Today I got the engine to turn completely over but is a little stiff. Good sign. But the oil had some booger stuff in it and a little water. Not good.
So, I went out and looked at the truck. I have the box and front fenders off. On the rear axle one side had a plate on top. Only one side. I looked in the 47-54 assembly manual and saw nothing of the sort. What is it? Should there have been these plates on both side? And were there springs on top of them? The springs are mounted on the bottom of the axle like it shows in the book.
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | sure wish we had some pix..............dont cha hate that response  I am trying to remember what mine looked like before removing the old rear end and having the blazer one put in.... I thought I remember plates but not sure.. I know.. big help.. good luck with it though Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Don't know what the "plate" was for, but there is a bracket on the passenger side that is used to mount the brake line "t" fitting. The brake line hose connects at this point. Hope this helps. lol | | | | | Joined: Jul 2005 Posts: 71 Member | | Member Joined: Jul 2005 Posts: 71 | Some sludge in the sump is normal if the engine was using non-detergent oil. A small amount of water is also nothing to worry about, as condensation will have settled in the sump over the time that the truck's been sitting idle.
But once it's back in regular use,water shouldn't be evident in the oil - something's wrong if that is the case. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | 1951 chevy truck - thanks for the picture.
The plate that I spoke of looks like it holds the springs (helper springs?) on the top of axle.
Are these helper springs important?
