| | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | For the first time in god knows how long, the 216 in the '46 1/2 ton roared to life last night!
Fired it up again this afternoon for about 2 minutes just to make sure I wasn't imaginging things last night.. it came without a fan, and has a seized generator (big dent in the bottom), so i've gotta replace those things and put some coolant in it before I dare run it any longer than that.
The good news is during it's two minute run today she idled all on her own, and when i'd goose it, the vac advance for the distributer seemed to work fine.. smooth running and no backfires.
Once I get the fan, generator, and belt on it, i'll try moving it and see what happens.. that outta be in the next couple hours.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Fumblin, Bravo  A big dent in the bottom. I remember the generator case as being almost a 1/4" thick, add to that the field coils and it seems like it would be impossible to dent the thing! Must have happened OFF the engine! Stuart. | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Congrats Fumblin.
That's gotta be the sweetest sound you've heard in weeks. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Yea.. she pops right off now.. it sure is a sweet, sweet sound.
Fan on, generator on, belt on, stomped on the foot starter and she popped right off.
Hopped in, put it in gear.. nothing.
Lifted the floor pan, and whadda ya know.. the u-joint is open. No bolts, no nothing to hold the joint together.
Let me take a moment to say that TORQUE TUBE STUFF SUCKS!
There.. I feel much better.
Now I have to source a supplier for the bolts and berrings I need to put the joint back together.
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Originally posted by atomarc: Fumblin, Bravo A big dent in the bottom. I remember the generator case as being almost a 1/4" thick, add to that the field coils and it seems like it would be impossible to dent the thing! Must have happened OFF the engine!
Stuart. Yea, I was pretty suprised to see the dent, too.. considering how heavy duty these generators are. In addition to being heavy steel, theres a "pan" underneath it when mounted.. so I doubt something like road debris could have caused the dent. The engine does look like it's had some head work done, there wasn't a fan on it, and the driveshaft was disconnected from the tranny.. perhaps a previous owner had the engine out to do some work and dropped it while it was out?
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Way to go, Fumblin!! I knew you'd have that thing running before very long! | | |
