3 members (Jay R, Otto Skorzeny, 1 invisible), 79 guests, and 3 robots.
Topics128,128
Posts1,056,684
Members48,452
Junior Member
Junior Member
I want to fill the fuel filler neck hole on the driver side of my cab. I am putting in a rear tank, the truck is a flat bed, and I want the filler at the tank. Does any one make a patch panel with the correct curve to fill this hole? If not, any tricks on how to make one?
John.
Anonymous
Unregistered
Anonymous
Unregistered
Either find an old junker and cut the piece off the other side of the cab or just make it out of an appropriate gauge sheetmetal you may have lying around. You will probably have to smooth it out with some filler any way after welding and grinding. You can always leave the filler tube in place and put a locking cap on it.
Junior Member
Junior Member
Hadn't thought about using a piece from the other side. There's a junkyard nearby that had one older truck -- I guess I'll have to go have a look at it.
John.
Here's what was done on my '56.
[img]http://jbhardin-gallery.com/trucks/hole.jpg[/img]
It's a power antenna.
Junior Member
Junior Member
Mine has a frenched power antenna on the other side already. I guess I could put in a second one smile
