1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 27 Junior Member | | Junior Member Joined: May 2005 Posts: 27 | I'm up to my ears in suspension removal. A simple spindle swap has me replacing alot more than planned but while I'm in there... Are there any tips on getting the cross shafts off of the A-arms? Do I have to replace the cross shafts when I put in new bushings? Thanks.
Priorities make dreams happen.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You didn,t say what year you are working on. I,ll assume it,s 60-72. Unscrew the caps from the A-arm & remove the shaft. It all comes in a kit. Put the seals on the new shaft. Put the shaft in place & start one cap. Start the other cap to keep it all lined up. Screw the caps in tight & measure to make shure the shaft is centered. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2005 Posts: 27 Junior Member | | Junior Member Joined: May 2005 Posts: 27 | I just got the old caps off and they are threaded on the inside and the outside. Mine were really gunked up. Are there supposed to be threads on the A-arm? Do the caps spin with the shaft or the arm? Thanks.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The caps screw into the a arms & should fit tight. They pivot on the shaft. Usually the new caps are a little o-sized to fit tight in the a-arm. If they don,t you can have them welded to the a-arm to keep them from turning. If you keep them greased they will last practically forever. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
