3 members (jmoore, baldeagle, Eisenholtz), 67 guests, and 2 robots.
Topics128,037
Posts1,055,469
Members48,424
#190802 10/04/2005 10:08 PM
Hi all,
I'm new to stovebolt, and I'm glad to have found the place - great info!
I am a poor 19 year old punk from the darkest backwaters of southeast Missouri. My truck is a 64 C10, which I finished building a 357 vortec for over the summer. I also bought a saginaw car 4-speed to slap on her, which leads me to the subject of this post:
Who knows a 4-speed shifter for this car tranny that's got a shift handle like my truck's old top-loader? These short-handled jobs are gonna have me craning over the floor pan with every shift. Is my only option a custom weld job? Info, info, please, please, please. And thanks.
#190803 10/05/2005 3:58 AM
Don't know about any top loader conversions. I f the old truck was a three on the tree they can be converted to a four speed tranny. I did this on a 53 one time and worked will well.
#190804 10/05/2005 7:49 AM
If you go with an aftermarket shifter(Hurst,etc.) it isn't too hard to build a shifter extension; I've even used threaded rod with the same thread as the shifter,you can bend it to put the knob where it's comfortable to use.Use a steel long-nut and two short jam-nutsto attach it to the shifter,and you might have to make an adapter at the top depending what shift knob you want to use. Use red loctite to assemble the bottom coupling. Once you have it all together except the knob,slide a piece of that foam tube stuff for insulating pipes over the whole shifter,from the bottom clear up to the top of the threads. Use a size that just fits over the shifter,and when you tighten the knob down,it'll look like a one piece shifter,custom bent to fit you.You can probably stretch the shifter boot opening enough to fit over the foam to add the finished look. (With a dremel you can even customize the top of the foam tube to provise some finger clearance wherever your fingers would lie when you shift.
Just one suggestion.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#190805 10/05/2005 11:22 AM
http://go.mrgasket.com/pdf/HURST.pdf
Go to page 18, shifter 391 0001, kit 373 7919
Go to page 49 to see stick drawing 538 4311
#190806 10/05/2005 4:32 PM
Thanks for all,
these are the freshest ideas I've come across in a while.
Bluto
#190807 10/05/2005 4:41 PM
Yeah, that's the one, chuckthetruck.
I've been researching Hurst for some time and never saw this one. Big thanks.
#190808 10/06/2005 11:09 AM
Socket Breaker
Socket Breaker
speed - that's good thinking there.
-W
