7 members (Otto Skorzeny, J Lucas, dt235sd, Cosmo, jeffreyguy, Charles in CA, LAROKE), 132 guests, and 6 robots.
Topics128,107
Posts1,056,221
Members48,436
#190674 10/04/2005 3:35 AM
Does anyone have instructions for a rebuild kit on a 53 3600 master cylinder. I have the wheel cylinder kits and a master cylinder kit that the PO bought for the truck. The master cylinder kit is missing the instruction. (of course I have four wheel cylinder instruction sheets)
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
#190675 10/04/2005 10:41 PM
Riding in the Passing Lane
Any shop manual should have the breakdown but it,s pretty basic. Line the parts up the way they come out. Hone the cylinder & reassemble it like it was. Bench bleed it before you put it back on. To bench bleed clamp it in a vice level. Fill it about half full of fluid. Push in on the rod & put your finger over the hole where the line goes in. Let the rod come back. Wait afew seconds & keep doing this till fluid squirts out the hole. Mount it on the truck & clean up the mess. Do not let fuid get on your paint. It will spot it bad. smile
1972 Chevy c10 Cheyenne Super
#190676 10/04/2005 11:17 PM
What paint?
Thnaks for the tips.
I will need to get a manual.
1953 3/4-Ton Chevy
More pix
RB53
#190677 10/05/2005 2:59 AM
Don't let the fluid get in your eyes either. Hurt like crazy.
I like old trucks
