2 members (Gray_Ghost, 1 invisible),
238
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Does anyone have instructions for a rebuild kit on a 53 3600 master cylinder. I have the wheel cylinder kits and a master cylinder kit that the PO bought for the truck. The master cylinder kit is missing the instruction. (of course I have four wheel cylinder instruction sheets) | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Any shop manual should have the breakdown but it,s pretty basic. Line the parts up the way they come out. Hone the cylinder & reassemble it like it was. Bench bleed it before you put it back on. To bench bleed clamp it in a vice level. Fill it about half full of fluid. Push in on the rod & put your finger over the hole where the line goes in. Let the rod come back. Wait afew seconds & keep doing this till fluid squirts out the hole. Mount it on the truck & clean up the mess. Do not let fuid get on your paint. It will spot it bad.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | What paint? Thnaks for the tips. I will need to get a manual. | | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | Don't let the fluid get in your eyes either. Hurt like crazy.
I like old trucks
