6 members (Shaffer's1950, Stovebolt48, Eisenholtz, Hotrod Lincoln, 2 invisible), 53 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#190612 10/01/2005 10:17 PM
Riding in the Passing Lane
Where do I find the casting numbers on the block on a 54-55 6 cylinder? :confused:
1972 Chevy c10 Cheyenne Super
#190613 10/01/2005 10:33 PM
On the top of the starter towards the front of the engine. It's cast (raised) Example B125 Would be B=February, 12=12th of the month, 5= 1955.
#190614 10/02/2005 2:44 AM
The casting numbers (7 digits) on my '54 is located in front of the fuel pump on the lower edge of the block near the oil pan.
#190615 10/02/2005 2:45 AM
#190616 10/02/2005 2:47 AM
#190617 10/02/2005 2:48 AM
The casting numbers (7 digits) on my 54 is located in front of the fuel pump on the lower edge of the block near the oil pan.
#190618 10/02/2005 2:57 AM
The casting numbers ( 7 digits ) on my '54 are located in front of the fuel pump on the lower edge of the block down near the oil pan lip.
#190619 10/02/2005 2:59 AM
#190620 10/02/2005 3:00 AM
The block casting numbers ( 7 digits ) on my '54 are located in front of the fuel pump on the lower edge of the block down near the oil pan lip.
#190621 10/02/2005 3:04 AM
#190622 10/02/2005 3:08 AM
#190623 10/02/2005 6:47 AM
X
X Offline
Check the picture in this thread.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
