2 members (Uncles51, Shardean),
50
Mod | | | Forums66 Topics128,021 Posts1,055,356 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Where do I find the casting numbers on the block on a 54-55 6 cylinder? :confused: They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | On the top of the starter towards the front of the engine. It's cast (raised) Example B125 Would be B=February, 12=12th of the month, 5= 1955. | | | | | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | The casting numbers (7 digits) on my '54 is located in front of the fuel pump on the lower edge of the block near the oil pan. | | | | | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | The casting numbers (7 digits) on my '54 is located in front of the fuel pump on the lower edge of the block near the oil pan. | | | | | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | The casting numbers (7 digits) on my '54 is located in front of the fuel pump on the lower edge of the block near the oil pan. | | | | | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | The casting numbers (7 digits) on my 54 is located in front of the fuel pump on the lower edge of the block near the oil pan. | | | | | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | The casting numbers ( 7 digits ) on my '54 are located in front of the fuel pump on the lower edge of the block down near the oil pan lip. | | | | | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | The casting numbers ( 7 digits ) on my '54 are located in front of the fuel pump on the lower edge of the block down near the oil pan lip. | | | | | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | The block casting numbers ( 7 digits ) on my '54 are located in front of the fuel pump on the lower edge of the block down near the oil pan lip. | | | | | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | The block casting numbers ( 7 digits ) on my '54 are located in front of the fuel pump on the lower edge of the block down near the oil pan lip. | | | | | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | The block casting numbers ( 7 digits ) on my '54 are located in front of the fuel pump on the lower edge of the block down near the oil pan lip. | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Check the picture in this thread.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
