1 members (Peggy M),
121
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | This might have been answered earlier, but here it is again. Why aren't the rear wheels on AD truck centered in the fender cutouts?
Stuart. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | No one knows for certain. When I die that will be the first question I ask.  Of course, I won't be able to tell you.
Fred 52 3600 69 C-10
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | With the way the springs are mounted, don't the wheels move back in the well as the load increases? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | GMCpanel, You are exactly right, but even with the Titanic in the bed of the truck the rear shackles won't swing back far enough to center the wheel in the opening (I think). This goes hand in hand with the strange fit of the hood to fenders. I don't know if this funky hood fit can be adjusted out or not. I always figured the fellow running the huge hood press was drinking gin on his Wheaties and maybe smoking hemp at break time!
Stuart. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I think it was just a styling choice. Personally I think it looks better that way.
I think it's kind of the same reason you have to put a crown in a long doorway or it will look like it sags.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Originally posted by atomarc: GMCpanel, You are exactly right, but even with the Titanic in the bed of the truck the rear shackles won't swing back far enough to center the wheel in the opening (I think). This goes hand in hand with the strange fit of the hood to fenders. I don't know if this funky hood fit can be adjusted out or not. I always figured the fellow running the huge hood press was drinking gin on his Wheaties and maybe smoking hemp at break time!
Stuart. I would have paid good money to see how they dealt with hood fit and ring and pinion setup on the AD assembly line. Here's another thing I've noticed about the 47-54 trucks - every one that I've seen so far has a different gap between the front edge of the running board and the back edge of the front fender when comparing the left side to the right side. Kinda like having different hubcaps on one side of the vehicle I guess. No one notices. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Partly because of the torque tube set up too. As there is no rear u-joint the axle the axle will move backward a bit when it hits a bump or takes on a load. I learned this when I raised the front of the truck on stands to get to the trans and u-joint. I pushed the torque tube up to clear. When I put everything back I lowered the truck to reassemble the u-joint ball housing but the torque tube would not clear the rear of the trans. I had to raise the front of the truck again so the whole unit would move back an inch. | | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | I could see the torque tube expalnation for the half tons with the way they hook up to the rear end, but why are the 3/4 tons not centered when they only have half a torque tube and the rear end is mounted solid to the springs? Ralph | | |
