Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Phak1, Tom McGrath), 119 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#189679 09/18/2005 1:58 PM
ODSS Lawman
ODSS Lawman
On the way to my new home in my 51, my speedometer stuck on 35mph. This is the first time this has happened. I removed the speedo cable and it returned to 0. I reinstalled the cable and the needle does not move but the odometer still works.
Yesterday I removed the speedo, took it all apart, reassembled it, tightened all the screws, and the same thing happens. The needle does not move but the odometer still works. If I turn the linkage by hand the needle will move and return to the 0 position.
If I had a broken cable, nothing would work? Or is this not true????
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
#189680 09/18/2005 4:08 PM
Riding in the Passing Lane
The cable may be too long. Try leaving the connector a little loose. If that is the problem you can cut it off a little.
1972 Chevy c10 Cheyenne Super
