5 members (lumbersawyer, tclederman, TUTS 59, 39Master85, 1 invisible), 38 guests, and 3 robots.
Topics128,083
Posts1,056,331
Members48,442
#189659 09/18/2005 2:01 AM
Just installed me some dual electric air horns,long trumph style in my,52 much louder then stock.. wanted some of those fire truck type but these will cause a few to open their ears grin :DFred
Redryder pix
My Hotrod
#189660 09/18/2005 4:23 AM
Tell us more! Who's the manufacturer? Where did you mount them? Did you use the original horn button or mount an auxilery? Are you happy? Post pictures.
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
#189661 09/18/2005 1:33 PM
I'm with Jerry when you can. Last air horn I had was back in HS and was off a Santa Fe locomotive. Loud was not the word and scared the hell out of folks but was a good laugh to a bunch of 17 year olds.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#189662 09/18/2005 3:23 PM
I used the after-market horn button that was under the dash, mounted them behind the front grill, so that meant taking the hood plate off, had to do a little make shift bracket to the center grill frame, add new wiring from new horns to old wiring and bingo, I got me some noise power now, the old one you could bareley hear but now wow........did not think to take pix and hence not going to remove the hood plate again,,,real easy job or I would not have done it, the only thing you have to look out for is how long the trumphets are, mine just got in behind the grill and each one was 13 inches, you have to make sure you have them low enough so that you can get the hood plate back on, you can buy shorter ones but I just felt like the longer the better grin Fred
Redryder pix
My Hotrod
#189663 09/18/2005 3:31 PM
Thanks. Where did you get those horns?
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
#189664 09/18/2005 5:06 PM
got these from O'rellys,, about 40 bucks, like ever thing else the, horns are plastic, you can get them even cheaper, I think these will serve my purpose,,I believe the name on the package "BIG BOSS" and yes, they were made overseas(Italy), the old horn(Round)located on the firewall just did not cut it,,,,,,these aren't like the firetrucks that you hear but a lot louder then what I have...the package contains 2 trumphet horns, plastic tube(to cut)small metal compressor,bolts, nuts, and relay if you need it... you have to supply wiring,,your old wiring might be long enough depending on how long and where you mount it,, I think behind the grill is the best place, out of sight for sure and less water and stuff to get in....Fred
Redryder pix
My Hotrod
#189665 09/18/2005 5:15 PM
Was thinking about air horns, and getting a partime job at O'Reillys just to see if I could get a discount..Being retired, all I do is work on the truck, and NO Joker I don't just tinker and drink beer..Well maybe sometimes..Got my dashboard done yesterday, so there..Going crusin today, and just so happen to have the first Canned Heat CD in the box..Steve
#189666 09/20/2005 12:43 AM
canned heat cd, is that country..............what do you think about me moving my after market horn button from my steering column to the floor, maybe close to my dimmer switch??
Redryder pix
My Hotrod
#189667 09/20/2005 1:33 AM
Just save yourself the hassle of having to hit the horn and hook it up to your brake lights. grin
#189668 09/20/2005 2:03 AM
grin grin grin
Redryder pix
My Hotrod
#189669 09/20/2005 2:40 AM
I like the brakelight idea, but I think you need a hanging chain from the headlinder with a great knob...I guess we got us a convoy..Now I got to get some airhorns..Take care bro..Steve
#189670 09/20/2005 3:30 AM
try ebay
The following is a listing for all 12v horns by lowest price.
Ps you don't need an expensive horn for it to be LOUD. Mine were 10bucks and that included shipping for a (dual) set of 130dB loud!! Fiamms.
http://search.ebay.com/12-volt-horn_W0QQfromZR40QQfsooZ1QQfsopZ3
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
#189671 09/20/2005 8:49 PM
Fiamm makes pretty good horns. I'm going to steal the set of Bosch horns out of my BMW before I get rid of it. Man, they are loud, and sound good. A nice two tone teutonic honk.
Paint & Body Shop moderator
#189672 09/20/2005 9:49 PM
I believed that mine are Fiamm,,,, I was out drivin the 52 today,not sure why, it is only about 100 degrees, at any rate, all is well then my cd starts to cut out and finally it stops, I start looking under the dash to see if I can see any wires that might be off.. everything looks good so I come in to cool off, wife says, do you think your new horns have anything to do with it,,I say it does make you wonder but I doubt it so I go back out and get hot again and finally decide to check the horn, sure enough no horn,,I pop the hood, check the hot wire, looks ok, jiggle it a little, I have a horn and power to the cd,, just did not have a good enough connection.. I suspose the next time your wife gives you a hint, it might be worth while to listen
Redryder pix
My Hotrod
#189673 09/20/2005 10:40 PM
The horn and radio are connected together, ya lost me ??
but you're right about the wifey part ....
Jim & Caroline
#189674 09/20/2005 11:09 PM
some-how the hot wire is used for power for both
Redryder pix
My Hotrod
