0 members (),
172
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18960 11/08/2004 3:25 AM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | I've found a replacement for my 216 with the cracked block in my 46 1/2 ton. It come from a 39 car, with a 3-speed. My truck has the old crashbox 4-speed. Will I need to swap the bell-housings, or are they the same. Also, is it harder or easier to pull (and put back)the motor and tranny together or apart. Any other helpful hints on swapping out this engine and tranny? Thanks! | | |
#18961 11/08/2004 4:12 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The bellhousing bolt pattern is the same but the 1939 uses a four bolt flywheel so you must use the 39 flywheel. Other than that it should be an easy swap.
By the way 1939 was the last year to not use a rear main seal on the crank.
If you have the front fenders off you can pull the trans with the engine, otherwise pull the trans first. With the fenders on I believe you will need to pull the bellhousing off to clear also.
See the USA in your vintage Chevrolet! My Blog | | |
#18962 11/10/2004 5:37 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Do I actually need to pull the tranny, or can I leave it in, (supported of course)? Also, on the flywheel, I thought that perhaps the truck transmission might have a bigger flywheel than the car? I guess I won't really know until I get it all out and compare this weekend, but just trying to anticipate where I might run into any problems. Last question... The motor has been sitting about 6-months, any special considerations (lubrication or ?) that I should consider before I try and fire this thing? | | |
#18963 11/11/2004 5:30 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The standard clutch for pass and PU is 9 1/8". Of course the truck could have the optional 11" clutch. The flywheels are the same size.
If you have the front fenders off you could leave the trans in place.
Six months is not that long for a engine to sit. I have pulled engines apart that have sat for many years and the bearings were still full of oil. If moisture has gotten to the engine I would put a little oil in the cylinders through the spark plug holes.
#18964 11/11/2004 9:19 AM | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | for sure oil the cylinders before cranking i didnt and it cranked over two weeks later i tryed it again it froze up tite and is still not loose after 6 months soaking in oil i should have listined to the old guys they told my to oil it up first | | |
#18965 11/11/2004 4:22 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Thanks guys for the answers and patience. As I said, I'm trying to anticipate anything that might go wrong or cause issues on this swap. I live several miles from any parts sources so it's a pain in the butt, if you don't have exactly what you need, when you need it. I also tend to over-think these processes, i.e. leave the tranny in or take it out? | | |
