5 members (J Lucas, Brian Moore, Pete1946, Otto Skorzeny, Hotrod Lincoln), 124 guests, and 3 robots.
Topics128,072
Posts1,055,903
Members48,429
#18950 04/30/2003 10:40 PM
Socket Breaker
Socket Breaker
Trying to find what tranny I have...
I have an auto tranny in my truck. It has the vacuum line that goes from the back of the Holley 4 barrel carb. to the tranny. I am fairly sure the engine is some year of the 5.7 L block, at least the oil filter seems to think so. smile
On the tranny, on the driver's side, on the bell housing is the only number I have found so far:
8640800
the last 8(the one between the zeros) looks like a backwards 3, but I figured it was just wear since the 4 is the right way up.
anyone have any clue? Any have anywhere to point me? smile
Thanks...
-W
#18951 05/01/2003 3:04 AM
Junior Member
Junior Member
the oil pan on auto transmissions are what you use to identify them.
#18952 05/01/2003 5:59 AM
Does your tranny pan shape look like this one which is a TH350
http://www.4wheeloffroad.com/4wheeloffroad/techarticles/p99310_image_large.jpg
http://home.hiwaay.net/~ppatter/auto_tranny_id.htm
#18953 05/01/2003 2:37 PM
Here's a good source for tranny i.d. Nowak Tranny page
Fred
52 3600
69 C-10
#18954 05/01/2003 4:05 PM
