5 members (GMCJammer51, Phak1, Greg_H, WICruiser, tclederman), 93 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
OK, bad day for me. I spent most of this afternoon repairing the spotlight on my truck. I actually got it working, cleaned everything up and adjusted it. Then, when I was reassembling the reflector and glass lense, I fumbled the glass & broke it. I'd have a nasty hole to fill in the window post if I eliminated the light, eh?
Does anyone have one of these lenses laying around by any chance? The company that made the thing is Casco, of Bridgeport CT.
[img]http://webpages.charter.net/fredstev/spotlight.gif[/img]
Try your local Police Supply store. Believe it or not they still use a simular style that you should be able to adapt.
Just find a Unity and be done with it. Replacement parts are much easier to be done.
1954 GMC De Luxe COE
Do a search on E-bay for a unity. There should be a million of them on there.
Excellent idea on swapping to a Unity. I'm checking for 6 volt spotlights on Ebay right now.
I wonder if anyone would sell a 6V bulb? That way you could buy a semi-modern Unity and drop in the 6V bulb.
The new ones all have black plastic heads. They work nice...but..No Chrome...
Quote
I dunno. I have a question in to an Ebayer about that right now. There's a lot of"antique" Unity spotlights listed, but no one sez anything about voltage.
It would take some serious cobbling to convert the Perfection light that I have now to anything else, the bulb socket is single wire in the center with a connection that allows it to pivot and still make connection. Ground is common thru the truck cab. Works good though.
Unity still sells the parts for all of those, including 6v bulbs. unityusa.com
