3 members (tclederman, Bill Hanlon, 1 invisible), 197 guests, and 3 robots.
Topics128,106
Posts1,056,213
Members48,436
After a lot of back and forth about the length of the vin number and and identifing the classifcation in there records I finally ordered my resto packet, I just hope its the right info. I have a 1950 3100, the rep. said it was classified as a 'CKpickup' - Whats does that mean? It was either that or the sedan info so I'm sure its right but what does it stand for?
While I'm here - my Vin is 8HPE 9770
did I decode it right?
8 = Atlanta Georgia
HP = 3100 - comm. light duty
E = Built in May
9770 = # 8770 to roll out of the plant
I used a decoder from a site and it said it was made in Sherveport, LA????
I can't tell how much I'm on this site, Thanks for the help!
Paul Kris
The C/K Pickups were from 1960 an later, but maybe they classify all the light trucks that way.
X
X Offline
You got it right. The H in HP denotes the model year, 1950.
The C/K designation didn't come about until the '60 models. C=conventional cab 2WD, K=4WD.
For resto packs, there are only the two choices--car or truck. As long as you are getting the truck pack for your year, you're OK. The truck packs cover all models from 1/2-ton to 2-ton.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
Welcome to the site, Paul! Be sure to use the menu bar at the top to explore the other section of the site (in case this bulletin board was your entry point).
Keep the questions coming, that's what we're here for.
Regards,
John Milliman
~ One of many.
Paul, some times when you call you get the Rep who should be working at McDonalds insteat of GM.
Did you get fries with that????? Try calling again and talk to a diffrent rep your luck will probally improve.
Regards,
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
