0 members (),
106
0
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 11 New Guy | | New Guy Joined: Jun 2005 Posts: 11 | After a lot of back and forth about the length of the vin number and and identifing the classifcation in there records I finally ordered my resto packet, I just hope its the right info. I have a 1950 3100, the rep. said it was classified as a 'CKpickup' - Whats does that mean? It was either that or the sedan info so I'm sure its right but what does it stand for?
While I'm here - my Vin is 8HPE 9770 did I decode it right?
8 = Atlanta Georgia HP = 3100 - comm. light duty E = Built in May 9770 = # 8770 to roll out of the plant
I used a decoder from a site and it said it was made in Sherveport, LA????
I can't tell how much I'm on this site, Thanks for the help! Paul Kris | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | The C/K Pickups were from 1960 an later, but maybe they classify all the light trucks that way. | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | You got it right. The H in HP denotes the model year, 1950.
The C/K designation didn't come about until the '60 models. C=conventional cab 2WD, K=4WD.
For resto packs, there are only the two choices--car or truck. As long as you are getting the truck pack for your year, you're OK. The truck packs cover all models from 1/2-ton to 2-ton.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Welcome to the site, Paul! Be sure to use the menu bar at the top to explore the other section of the site (in case this bulletin board was your entry point).
Keep the questions coming, that's what we're here for.
Regards, John Milliman
~ One of many.
| | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Paul, some times when you call you get the Rep who should be working at McDonalds insteat of GM. Did you get fries with that????? Try calling again and talk to a diffrent rep your luck will probally improve.
Regards,
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
