2 members (Hush, delky), 141 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
#188013 08/19/2005 12:30 AM
Apprentice
Apprentice
would like to ask you guys if there is any place to buy regular rims for my 53? it has 8 bolt lug pattern. started to look on e-bay and could not find. called coker tire and found wide white walls 6.5" x 15, but they told me they do not carry 8 bolt pattern. hope some of you bolters with more experience will know where to get or order them. i will be going to fall Carlisle here soon to look also. if any one knows would appreciate it. thanks
bill
1953/54 3/4 ton
1955 2nd series 3/4 ton
#188014 08/19/2005 9:17 AM
Try Henderson Wheel,Salt Lake City,Utah 1-800-748-5111
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#188015 08/19/2005 12:10 PM
There are quite a few threads on this issue. The basic problem is finding a rim that will clear the front tie rod ends. Some have used trailer rims.
1951 1 Ton Completed
#188016 08/19/2005 12:34 PM
I used a 8 lug Chevy/Dod**/ F**d style rim with a 3/16 thick spacer ring and modern lug nuts. Just clears the rod ends and no problems in 16,00 miles.
#188017 08/19/2005 3:09 PM
Junkyards.. thats where i'd check first.
Find some old rims, get 'em sandblasted then painted or powdercoated.
#188018 08/19/2005 5:14 PM
I just got 4 16x6 wheels from Stockton Wheel in Stockton California. They worked out great. Kind of pricy, and a long lead time, but they'll make you a wheel with any backspacing you want.
They also offer a service to cut the centers out of your stock wheels, and weld them into modern rims. Keep your hubcaps, and run tubeless radials. Pretty cool.
Anyway I searched for years to find a 16" 8-lug wheel to fit my 52 1-ton. Finally got sick of looking.
-J
'52 3800 Panel
School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind.
inside of a dog it's too dark to read.
-Groucho Marx
#188019 08/19/2005 8:19 PM
Junior Member
Junior Member
I did the same as you did on my '53 3/4 ton, Blacksmithdon, with no problems. I got the D***e wheels for free off a friends '72 C/20. The radials cost $2 apeice at a swapmeet. The spacers were $18 at NAPA.
Sandblasted and repainted the rims. The tires look good with decent tread.
The ride with the radials is nice. Looks nice, too.
If anyone goes this route be sure to check the space between the tie-rod end and the edge of the rim. I have about three-eighths inch of clearance using the original style tie-rods. No sign of any contact between the two on mine.
Safety first - always.
Rick
I feel like I'm diagonally parked in a parallel universe.
