| | | Forums66 Topics128,126 Posts1,056,353 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 9 Apprentice | | Apprentice Joined: Aug 2005 Posts: 9 | would like to ask you guys if there is any place to buy regular rims for my 53? it has 8 bolt lug pattern. started to look on e-bay and could not find. called coker tire and found wide white walls 6.5" x 15, but they told me they do not carry 8 bolt pattern. hope some of you bolters with more experience will know where to get or order them. i will be going to fall Carlisle here soon to look also. if any one knows would appreciate it. thanks bill
1953/54 3/4 ton 1955 2nd series 3/4 ton | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Try Henderson Wheel,Salt Lake City,Utah 1-800-748-5111 Speed | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There are quite a few threads on this issue. The basic problem is finding a rim that will clear the front tie rod ends. Some have used trailer rims. | | | | | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | I used a 8 lug Chevy/Dod**/ F**d style rim with a 3/16 thick spacer ring and modern lug nuts. Just clears the rod ends and no problems in 16,00 miles. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Junkyards.. thats where i'd check first.
Find some old rims, get 'em sandblasted then painted or powdercoated.
| | | | | Joined: Oct 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 47 | I just got 4 16x6 wheels from Stockton Wheel in Stockton California. They worked out great. Kind of pricy, and a long lead time, but they'll make you a wheel with any backspacing you want.
They also offer a service to cut the centers out of your stock wheels, and weld them into modern rims. Keep your hubcaps, and run tubeless radials. Pretty cool.
Anyway I searched for years to find a 16" 8-lug wheel to fit my 52 1-ton. Finally got sick of looking.
-J
'52 3800 Panel School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind. inside of a dog it's too dark to read. -Groucho Marx
| | | | | Joined: Aug 2003 Posts: 31 Junior Member | | Junior Member Joined: Aug 2003 Posts: 31 | I did the same as you did on my '53 3/4 ton, Blacksmithdon, with no problems. I got the D***e wheels for free off a friends '72 C/20. The radials cost $2 apeice at a swapmeet. The spacers were $18 at NAPA.
Sandblasted and repainted the rims. The tires look good with decent tread.
The ride with the radials is nice. Looks nice, too.
If anyone goes this route be sure to check the space between the tie-rod end and the edge of the rim. I have about three-eighths inch of clearance using the original style tie-rods. No sign of any contact between the two on mine. Safety first - always.
Rick
I feel like I'm diagonally parked in a parallel universe.
