7 members (MickeyP, TGP, 68ironhead, Nhluvstruck, Otto Skorzeny, treegrower, Peggy M),
56
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Went looking for radial tires for my 49 and found Bridgestone 215/85/16 selling for $180 each plus mounting, valves and balancing and of course 15% sales tax! All Canadian dollars. That will equate to around $1000 by the time I am back on the road. I think for a truck that runs about 2000 miles per year it is a bit pricey. The tires are also 10 ply and I am wondering how stiff a ride that would give me especially when I carry very little or nothing in the box. Anyone have any ideas on less expensive rubber and something with fewer plys. Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | look for some Yokohama LT tires - my 700R15LT's were $712 for 4 all up - they're 10 ply and a little harsh, but not unbearably if you don't use the highest recommended pressure - got a Big O in the area?
Bill | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Thanks Bill there is one in town. They quoted me on the Bridgestones. Being 16" they could be pricier - ya think? | | | | | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | big o can special order kumho 215/85-16's for about $85/tire u.s. they are slim, high, black walls that ride great, corner well and don't cost a fortune. no white walls though in that size.
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
| | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Canadian Tire has Roughrider A/T tires on sale in the size you want for $100.49 each. Price includes mounting and valve. They are D rated (10 ply are E rated). www.canadiantire.ca
Gord 1954 1/2 ton 235 4 speed
| | | | | Joined: Oct 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 47 | I got a set of those Kumho's from www.tirerack.com They were in stock and then on my door in about 2 days. So far, they seem to be pretty good. Worth a look anyway. -J
'52 3800 Panel School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind. inside of a dog it's too dark to read. -Groucho Marx
| | | | | Joined: Oct 2002 Posts: 52 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 52 | I went to Costco Wholesale ~$100 each + mounting and balancing, out the door with 5 tires for under $600. These are BF Goodrich Radial Commercial Truck tires, load range D, 8-pli, they are tall, skinny and the ride is unbeatable. [img] http://www.kinemation.com/Trucks/gmc100/frontenddone.jpg[/img] These are LT215-85R16's running at 35 psi - they are rated to 60 psi, but too bouncy at that pressure. Costco is typically about 20 - 30 percent cheaper than the same tires at other stores.
Life's short - don't waste it.
