| | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Got em in today. All went smoothly, about 3 hours. Had to grind on the axle bumpers a little to get the new U bolts to fit right. It drives real nice. I might put a little more caster shim in it, but all's well. Got em from Performance online. Got some multileaf drop springs for the rear coming next week . Prolly add a sway bar next, but the monoleaf has helped body roll. Much better than the leaf removal job I had on it. :rolleyes: | | | | | Joined: Aug 2005 Posts: 11 Junior Member | | Junior Member Joined: Aug 2005 Posts: 11 | so what is typically better, the mono leaf, or dropped axle?
-Robb 56' 3100
| | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Never had a dropped axle so I couldn't tell ya. Just easier to install the springs rather than swap out all the king pins, springs, spindles, calipers, etc.. They are about the same price though. | | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | Now that a couple months have passed, do you still recommend them? Any problems? Your teruck looks good!!
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
| | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I'm happy with the monoleafs. It's a little bouncy but I think it's because I have the stock shocks. I should get a pair of shocks that are specifically for the monoleafs. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Shipwright,
I would be interested to know if there are any issues with the caster shims and the new monoleafs. Will you be taking your truck to a front end shop for an alignment, or is this something you would do yourself?
Stuart. | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Stuart, I got it all together, set the toe in to about 1/8", took it for a ride and haven't touched it since. Drives great except for the bounce. The only thing I haven't done is center the steering wheel. Just a hair off. I did buy 3.5° caster shims but don't think I need em. I used the stock ones. I gotta put new axle bumpers on soon so I might try the 3.5° shims just to see if there is any improvement. | | |
