1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#187679 08/15/2005 3:08 PM
Replacing a king pin... Anyone have any thoughts on a wicked stubborn set bolt?? This sucker doesn't want to budge... hammered it, heated it... nothin'!
Did the other side and that went as smoothly as a king pin job will go but this side seems to be pretty frozen up. In fact, it takes a little effort to turn the spindle by hand (without the steering arm hooked up even!) Now I see why my steering was such an effort!
Larry Bear
55.5 Chevy 3100 Panel
I eventually had to get a helper to support my axle across an anvil so I could get a full swing with a 12 lb sledge hammer. That was after 2 weeks of heating, cussing and beating with a smaller sledge. Good luck!
Mike Barnes
1950 GMC 1-ton pickup
Kyroil penatrating oil is great and more heat.
dan-pa
If the spindle is all that hard too turn , it may have turned into the set bolt and wore into it..?...Could be You just need to really fire it up with the smoke wrench...
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
Thanks! I'll be back at the garage tomorrow afternoon tackling the *#@%* bolt again... will let you know how it goes...
Larry Bear
#187684 08/15/2005 11:06 PM
I
I Offline
try heating it up and putting candle wax on it
rh
#187685 08/15/2005 11:10 PM
Riding in the Passing Lane
If someone is real good with a torch he can blast in the middle of it part way through on both sides & drive it out.
1972 Chevy c10 Cheyenne Super
Larry Bear,
What are you having a "hell" of a time getting out, the king pin or the tapered bolt that locks it in? You already did one side OK so
I'm sure you know the lock bolt is tapered and drives out from the threaded end. Is it the king pin that is frozen in the axle eye? These two items can become one and require much coaxing!! Heat the eye all around, wait several minutes and spray with WD-40 (or whatever) then grab a good pnuematic air chisel with a flat nose tool and,
using all your weight try driving the king pin down from the top! This has to work cause there ain't no plan B!! You must visualize the king pin moving in your mind !
Stuart.
#187687 08/16/2005 12:49 PM
It's the tapered bolt that won't budge. Have heated it up on both ends and in the middle... have used a good penetrating oil.... have used a heavy sledge... have used a pnuematic air chisel... have cursed a bit... OK a lot... We'll go back to it today.
Why candle wax im4racin???
Larry Bear
Larry, 25 years ago I had the same issue with one keeper on a 46 3/4t. After a week I gave up, pulled the axel and had the keeper pressed out at a machine shop. Cost me $10.00. I didn't have a torch, so i soaked the U-bolts in paper cups with tranny fluid for a few days, borrowed a 3/4 drive rachet with a 3' pipe on it and got everything off and 2 the machine shop.
Good Luck!
I had to drill mine out. I took my time and when I got near the wall of the opening, I quit. The remainder of the pin had no strength and I was able to drive the kingpin out. Now, moving the kingpin was another story. I had better success when I used a hardened wristpin for a drift.
1951 1 Ton Completed
I ended up drilling the sucker out yesterday... took 2 1/2 hours. But it's out! The king pin is pretty sealed in so that's next tomorrow.
Thanks for all of your suggestions!
Larry Bear
