0 members (), 123 guests, and 5 robots.
Topics128,078
Posts1,056,035
Members48,433
#187568 08/14/2005 11:17 PM
Junior Member
Junior Member
i have a 35' chevy pickup...and i had to drop the origional tank due to the fact it was rusted threw...so i decided to put in a tank i dropped from a 56'. The problem is the origional fuel bowl (gravity powered im told) isn't getting any fuel to the carborator. I have tried numerous fuel pump..but they keep going out on me....anyone have any ideas on how to get my bowl working for me (so far its all original except the gas tank and the spark plugs, wich i replaced last weekend)
#187569 08/14/2005 11:29 PM
Riding in the Passing Lane
You may be sucking air. Check the lines going to the tank & the gasket around the bowl. Have you had the pickup tube out of the tank. It may be broke, craked, or pluged up.
1972 Chevy c10 Cheyenne Super
#187570 08/14/2005 11:36 PM
Junior Member
Junior Member
i know the lines are clear...and not clogged (air compressor found out about that one)...all the lines are not leaking or anything...the bowls fills up but it stops there not to go into the carb.
#187571 08/15/2005 12:06 AM
Check your fuelpump pressure,4 to 7 lb.at carb fuel line.If pressure,check needle&seat in carb & float.If cam lob is bad for fuelpump.Pump no pump.But this is a long shot.Never heard of them going bad.Try a can of gas right to the carb fuel line,buy passing the pump and tank.Let us know what ya find.It,s just all common smarts
dan-pa
#187572 08/16/2005 6:30 AM
Junior Member
Junior Member
well i can get it to run...even drove it about 1/2 mile before my pump went out..but i just want to get the origional gravity feed working...and still to no avail ...guess ill just keep buying fuel pumps
#187573 08/16/2005 9:05 AM
make sure your gas cap is vented
#187574 08/16/2005 9:07 AM
unhook it line at the carb crank the motor see if gas gushes out
#187575 08/16/2005 11:19 AM
Maybe at the end try a electric fuel pump.Gravity was replaced to avoid this problem.As long as it runs,who cares how the engine gets it fuel.Updating is also for safety.
dan-pa
#187576 08/16/2005 12:24 PM
k10 Offline
6 volt electric fuel pumps are available from Delco. They are switchable to POS or NEG ground. You'll need a block off plate.
Or you could call Barry and see if he's got an original tank for you.
http://www.stovebolt.com/weeks/
