| | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6 Junior Member | | Junior Member Joined: Aug 2005 Posts: 6 | i have a 35' chevy pickup...and i had to drop the origional tank due to the fact it was rusted threw...so i decided to put in a tank i dropped from a 56'. The problem is the origional fuel bowl (gravity powered im told) isn't getting any fuel to the carborator. I have tried numerous fuel pump..but they keep going out on me....anyone have any ideas on how to get my bowl working for me (so far its all original except the gas tank and the spark plugs, wich i replaced last weekend) | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You may be sucking air. Check the lines going to the tank & the gasket around the bowl. Have you had the pickup tube out of the tank. It may be broke, craked, or pluged up. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2005 Posts: 6 Junior Member | | Junior Member Joined: Aug 2005 Posts: 6 | i know the lines are clear...and not clogged (air compressor found out about that one)...all the lines are not leaking or anything...the bowls fills up but it stops there not to go into the carb. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Check your fuelpump pressure,4 to 7 lb.at carb fuel line.If pressure,check needle&seat in carb & float.If cam lob is bad for fuelpump.Pump no pump.But this is a long shot.Never heard of them going bad.Try a can of gas right to the carb fuel line,buy passing the pump and tank.Let us know what ya find.It,s just all common smarts
dan-pa
| | | | | Joined: Aug 2005 Posts: 6 Junior Member | | Junior Member Joined: Aug 2005 Posts: 6 | well i can get it to run...even drove it about 1/2 mile before my pump went out..but i just want to get the origional gravity feed working...and still to no avail ...guess ill just keep buying fuel pumps | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | make sure your gas cap is vented | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | unhook it line at the carb crank the motor see if gas gushes out | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Maybe at the end try a electric fuel pump.Gravity was replaced to avoid this problem.As long as it runs,who cares how the engine gets it fuel.Updating is also for safety.
dan-pa
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | 6 volt electric fuel pumps are available from Delco. They are switchable to POS or NEG ground. You'll need a block off plate. Or you could call Barry and see if he's got an original tank for you. http://www.stovebolt.com/weeks/ | | |
