0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18743 01/09/2003 10:00 PM | Joined: Jan 2003 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 31 |
#18744 01/09/2003 10:08 PM | Joined: Jan 2003 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 31 | Gentlemen,
If this gets posted, it will be my first. I have a stock 1950 5-window pickup which is driven weekly. The column shift linkage needs rebuilding. I'd like to install a floor shift conversion. These used to be available all over when I was a kid, but now seem impossible to find. Is there a source (other than swap meets)for these kits?
Thanks, Bill
#18745 01/09/2003 10:33 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | dynasour, My 50 5 winder was also a 3 speed years ago but the PO changed it to 4 on the floor. Best thing that ever happened. Wife says it a lot more manly like. Hopefully someone with tons of resources will be able to help you out. Never done it, don't you only need:
1. 4 speed tranny with shifter (same length as a 3 speedo ?) 2. Fancy shift knob (maybe a deactivated hand grenade). 3. Floor tranny plate.
What else is there ? What is great is being able to eliminate all that column linkage.
Cheers
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#18746 01/10/2003 8:03 AM | Joined: Feb 2000 Posts: 5,191 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,191 | Try ( jcwhitney.com ) item #81ZH1086P $55.00 Daytona floor shifter. joe | | |
#18747 01/10/2003 3:47 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Joe, thanks for the link. Bill, I want to go the same route. You can also check out hurst . They have a 3 speed, floor shift for 55 AND UP 3100. I doubt thet either of these choices will be a direct bolt-on, as pre-55's are slightly different. Hey! Here is a great idea! Why dont you go ahead with the conversion and do a thorough pictorial? Yeah, that'd be swell! Whizzerick | | |
#18748 01/10/2003 4:43 PM | Joined: Sep 2000 Posts: 33 Member | | Member Joined: Sep 2000 Posts: 33 | Welcome, new folks. Try to do a search here by topic because this question comes up, and I remember some of our folks giving opinions on some conversion kits being significantly better than others. Best o' luck.
Ed b. | | |
#18749 01/10/2003 6:08 PM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | You may need to fab a plate above the transmission for the shifter to come through. The column shifters have a blank plate there.
HERE'S A TIP: Some folks are looking for uncut/unmodified original plates. Be sure to put it up on the swap meet if you go that route, and plan to have a new plate made up.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#18750 01/10/2003 6:38 PM | Joined: Nov 2002 Posts: 33 Member | | Member Joined: Nov 2002 Posts: 33 | looking for similar info what do i need to put a 4 on the floor i have a 51 1/2 ton got a 55 235 in it? please help! | | |
#18751 01/10/2003 6:58 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You need to find an SM420 transmission, which was the optional 4 speed for this truck. They are fairly common, and available for both closed and open driveline. They have a 6:1 1st gear ratio and weigh about 120 lbs. They bolt up to the stock bellhousing and driveline. The way to find one is to look for a 4 speed that has reverse to the left and back- that is, toward your knee and back. Avoid the ones with a lockout lever from '48 and earlier because they aren't synchronised.
#18752 01/12/2003 2:56 PM | Joined: Jan 2003 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 31 | So far the Whitney Daytona floor shift kit seems my best chance. Can anyone tell me how the pre 1955 and the later transmissions shift inputs differ, so I can see if this is a possibility for me?
#18753 01/12/2003 8:18 PM | Joined: Sep 2002 Posts: 72 Member | | Member Joined: Sep 2002 Posts: 72 |  howziit Bill! thirty-eight years ago, i had a '51 chevy sedan, with original driveline and ANSEN posi-shift. it was "okayyyy". it mounted on the trans, with existing bosses, i think. it's been SO LONG AGO! :rolleyes: the HURST MYSTERY-SHIFTER was their cheaper model, sold for $20-something. back then. the HURST SYNCHRO-LOK was their premier 3-speed shifter, sold for $30-something, i think.(this one had quality shifting, like their current 4-speed shifters. JMO, i would check on www.ebaymotors.com or place/check out classified ads on chevy websites. good luck, Bill
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
#18754 01/13/2003 1:41 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Fix your linkage and quit "Hacking"! Nothing worse than a floor shifter that don't work right and you have to bend over to reach or make a longer lever and have way long throws with it. You can rebuild the shift box on column under firewall and put new bushings in the link holes, using new brand bushings. Hurst will have those. It won't shift like a "Racer" either, unless you use a more modern trans, and that would require a new rear-end and driveshaft as you now have Torque-tube one-pc rear.
Can you tell I hate changing from stock? :p :p :p
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#18755 01/13/2003 10:49 PM | Joined: Sep 2002 Posts: 72 Member | | Member Joined: Sep 2002 Posts: 72 |  howziit again guy! i saw two universal 3-speed shifters yesterday, at checkers auto parts. one was a HURST, one a MR.GASKET. apparently, they're still available.
Myron
#18756 01/14/2003 12:46 AM | Joined: Jan 2003 Posts: 19 Member | | Member Joined: Jan 2003 Posts: 19 | Dino: Try Hot Rod and Custom Supply their somewhere in FL and advertise in most of the Hot Rod magazines. They specialize in old hot rod parts for flatheads, inliners etc. I seem to recall they had an inventory on Ansen shifters and such. Perhaps they can help you out. Good Luck. | | |
#18757 01/17/2003 2:40 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I just took my aftermarket 3 speed floor shifter out and put in sm420 tranny. Mine is a 55 1st series, I will give it to you. You can pay shipping and anything else you see fit is fine. -Scott
55 1st Chev.
#18758 01/19/2003 6:37 PM | Joined: Jan 2003 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 31 | Scott,
Thanks for your kind offer, but I don't believe that a '55 shifter will fit. This is based on a telecon to Hurst to see if their advertised 55 could work with my '50.
Is it possible that your early '55 is the same as the '48 on? Does your tranny use a Hotchkiss enclosed drive like the earlier ones?
Thanks again,
#18759 01/19/2003 8:55 PM | Joined: Jan 2003 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 31 | Scott,
Started doing my homework, and found that the First Series '55 has a closed drive shaft like my '50. I'd like to take advantage of your offer to send me the 3-speed floor shift conversion.
Do you know the manufacturer? Will $25 be fair?
My home address is: William Stewart 839 Tamlei Ave Thousand Oaks, CA 91362 Phone 805-494-0519
#18760 01/20/2003 8:25 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Sorry, I dont have email at home. My 55.1 has an open drive shaft 1 piece. That was the first year for that. I dont know if it will fit yours. Get back to me.
55 1st Chev.
